Audi 100 Avant Q Sport(200 20v look-a-like - A question!!!)
Ignas.quattro
Ignas.quattro
little_e
Re: Audi 100 Avant Q Sport(200 20v look-a-like - A question!
Oh. Was that distributor red????
Ignas.quattro
They are always red , but some of them have an additional black plastic coverlittle_e hat geschrieben:Oh. Was that distributor red????
little_e
Yes... although yours seemed more greyish-gunkish
Ignas.quattro
Any ideas on the noise that appears when the clutch is NOT pressed? When I press the clutch , the noise disappears , when I release it - reappears.
Here is the video:
http://www.youtube.com/watch?v=e-yVxsdExrk&
Here is the video:
dado
In most cases, the bearing inside the clutch makes noises when depressing the clutch pedal.
Ignas.quattro
Yes, I know, but this is different...dado hat geschrieben:In most cases, the bearing inside the clutch makes noises when depressing the clutch pedal.
little_e
I would say it's a bearing inside the transmission, because the bearing inside the clutch has most force on it when the clutch is depressed.
My guess is a bearing inside the tranmission, most probably a bearing on the input shaft, because when you depress the clutch it will stop spinning.
The damage will come by using the incorrect oil and/or running the transmission without enough oil.
...just my opinion though...
Ignas.quattro
So , finally , after so much waiting, the purebred 200 20v USA instrument cluster arrived
Seems to be in a superb condition and still a virgin, with the VDO sticker untouched
Ignas.quattro
Finally installed the temperature display
Ignas.quattro
Found some rare goodies!! Will be preparing and installing them sometime soon, hopefully
Ignas.quattro
Already removed velour(it removed very nicely) and was about to put on (replace) the original leather from the current door panels, but the foam turned out to be just in pieces, completely worn out, so I'm now looking for someone to re-glue it back on, because it's too much hassle to make it on my own (including foam , so that it feels exactly like original). I was about to do it on my own, but there different types of glue , different techniques so that I just don't wanna ruin something , because I kind of have one shot to do it right
I cleaned them very thoroughly as well, because they looked like they were never ever cleaned , you can check the pictures here , just disgusting
dado
your pictures don't work mate.
Ignas.quattro
Hmm, that's strange, because they work just OK for medado hat geschrieben:your pictures don't work mate.
Ignas.quattro
- DerSportkombiDavid
looks good with original rims. I´ve got "Gullideckel" for winter too, now i´m thinking of doing the same for summer again.
greets David
greets David
MfG David
Augen auf und durch!
Ignas.quattro
Hey , thanks!DerSportkombiDavid hat geschrieben:Hi,
greets David
Gullideckel you mean the ones from A8??
Ignas.quattro
no, the ones that you´ve got on your car, but i have 6Jx15 4x108.
greets David
greets David
MfG David
- stwquattro
She´s looking gorgeous, Ignaz.
Hope u r doing good!
Best regards from Germany!
Sebastian
Sebastian
1993 Lada Niva 1600
1993 Lada Niva 1600
Anatolik39rus
Didžioji Audi! Aš taip pat neseniai davė interjero travertinas, bet jis dažytos juoda, trinamas lėtai!
Ignas.quattro
Anatolik39rus hat geschrieben:Didžioji Audi! Aš taip pat neseniai davė interjero travertinas, bet jis dažytos juoda, trinamas lėtai!
Please show me some pictures if you painted your interior in travertin - that is what I understood.
I also understood that you've used a google translate
Ignas.quattro
Private Messagedstwquattro hat geschrieben:She´s looking gorgeous, Ignaz.
Sebastian
Anatolik39rus
Hi Ignace, next week I'm going to Russia, on the way back will go through Belarus and Lithuania, will pass through Kaunas
really want to see your avant we floor area dries on it, you turned it into a masterpiece)))
I'm two years on the Russian site drayv2 there is a social network for cars, but decided to register and then, I wanted to gain experience for more)
By the way, here's a reference on travertine sauce: (
http://forum.group44.de/viewtopic.php?f ... &p=1408811 # p1408811
Ignas.quattro
Hey everyone!
Finally as wide as I wanted it to be , now I need it slightly lower
surely one of the best Avant Quattro Sport around. But you even know
Greets David
Greets David
MfG David
Ignas.quattro
Thanks, very nice to "hear" itDerSportkombiDavid hat geschrieben:Hi,
surely one of the best Avant Quattro Sport around. But you even know.
Greets David
Snow Racer
- Parkwächter
- Fuhrpark: 1990 Audi 100 MC2 (Current)
1990 Audi 100 NF (Wrecked but alive) - Wohnort: Norway
hmm... is it only exhaust tips or whole exhaust?
true... I didn't expected to see the ugly spots but as you said it was lousy paintjobI wish the car looked at least half as good in reality as it does in the pictures
and I have the photos [evil_laught] MWuhAHAha! [/evil_laught]
edit - now you have the anti lock button also
