RS2 carrier bracket guidance please
oldsklaudidub
Beitrag von oldsklaudidub »
So I have some Big Reds on loan for my porsche carrier bracket project that I have approved for my ProE class at school. The project is for my 5ktq.
Questions:
Are RS2 brackets what I need?
Are UrS4 strut hosing brake bracket holes the same as the 5ktq? (the brackets i got my dimensions from are a UrS4)
Are my dimensions correct in the drawing attached? (I hope Im not braking any rules by posting them, IDK if there even correct)
Is the bracket design the same for the Boxster, Boxster S, and Big Reg calipers to attach to the 5ktq strut housing?
rs2carrierbracketworkingfinal.pdf
(105.69 KiB) 432-mal heruntergeladen
88 5KTQ "White Widow"
95.5 UrS6 "SRS"
www.JustFourRings.com
Mario20v
Re: RS2 carrier bracket guidance please
Beitrag von Mario20v »
Maybee this will help you, but its in german.
http://mtsonline.mt.funpic.de/bremse.html
Or ask Karl S. via PM.
oldsklaudidub
Mario20v hat geschrieben:Maybee this will help you, but its in german.
I could not find the user name of Karl S. Do you have the user name?
95.5 UrS6 "SRS"
oldsklaudidub
I would like to use A8 312x25mm rotors PN# 8E0 615 301 R
Porsche Boxster S Calipers PN# 996 351 425 11 and 996 351 426 11
I am just not sure if my bracket dimension are correct. (shown in the pdf file above)
95.5 UrS6 "SRS"
