Lima oder regler ??
birke
Lima oder regler ??
Beitrag von birke »
When i start the engine the voltmeter shows: 8 volt
I then raise engine speed to 3000 u/min and then it shows: 13,5 volt
And it STAYS at 13,5 volt
I can drive without draining battery.
Is the problem my Lima or Lima-regler ??
Antworten sie bitte auf deutsch, wenn erforderlich....
Cheers from Birke (Norway) :wink:
Carsten 200 20V Avant
Beitrag von Carsten 200 20V Avant »
Hallo, Willkommen hier im Forum.
Das Problem ist bestimmt der Regler. :wink:
Gruß Carsten....
Teilehändler
Zubehör und Tuningteile
www.rs-power-shop.com
Beitrag von mAARk »
Hi Birke,
The problem is probably NEITHER the alternator (Lima) NOR the voltage regulator (Regler), but rather the thin blue cable that is connected to the voltage regulator.
The blue cable comes from the instrument cluster (Kombiinstrument), to be specific: from the battery warning light. When the ignition is switched on, the blue cable carries battery plus from the warning light to the voltage regulator. This "triggers" (Deutsch: erregt) the regulator. As soon as the engine runs, the alternator starts generating power, i.e. the voltage inside the regulator increases to 13,5 volt. This means that both sides of the battery warning light are now connected to plus, so it switches off.
If the blue cable breaks, the regulator is not triggered. Only when you increase the engine speed, the voltage regulator triggers itself (this is because of residual magnetism). At this point, suddenly the voltage jumps up to 13,5.
QUESTION: if you switch your ignition on, does the battery warning light come on? I suspect: probably not!
Scenario 1: the warning light does not work:
Please inspect the light blue cable on the voltage regulator. You will probably find that it has
1) broken off or
2) corroded
Repair the cable, and the problem should be fixed.
Scenario 2: The warning light DOES work when you switch the ignition on (and it only switches off after you have revved up to 3000):
This probably means that the fault is inside the voltage regulator (Regler) itself, and it needs to be replaced.
Good luck, and regards,
turbaxel
Beitrag von turbaxel »
Welcome Birke Bild
It's probably the 'regler'. But it could also be the 'erregerleitung' (the wire from the battery dash light to the Lima) ;)
If it's corroded, broken or falsely connected, or the dash light dead, the 'lima' won't get an magnetic field until it reaches 2000 rpms apprx. It then becomes self induced and can load the battery.
The 'regler' is available @ your local Bosch dealer for apprx. 225 Kronen ;)
Best Regards,
turbaxel
PS.: Any pix of your sledge? ;) Bild
Alles Gute,
turbaxel
http://audi100.selbst-doku.de
