Audi UR/200/90
Johan
Audi UR/200/90
Beitrag von Johan »
i need a little help. :roll: i just made the engine swap -> audi 200 turbo engine KG into audi 90 typ89...
flywheel is from audi 90 20V, TDC pin marks are similar with 200` flywheel.. :-)
the next thing is wiring - i have MAC-01 ECU from URQ (chipped), but it is impossible to start engine :shock: when we drag in, engine starts immediately and everthing works fine!!! :twisted:
maybe it is because that urq flywheel has two timing pins ???????
Beitrag von Olli W. »
as far as memory serves me, you´ll need the following 3 signals to get the engine running.
- hall sensor signal
you need the turbo distributor with single hall window - n/a distributor with 5 windows will not work in l5 turbo applications.
- TDC reference sensor
you mentioned it - flywheel pin is pointing towards the engine @ 62° BTDC
- RPM sensor
sits next to the TDC sensor on the same mounting bracket. I guess, you need to have a flywheel with 135 teeth, otherwise, it wont work.
If one of these signals is missing, the engine will not spark.
HTH,
Johan
Beitrag von Johan »
a have the turbo distributor..
RPM sensor works fine
the problem is -> i have flywheel with only one pin, urq has two! :-(
http://www.quattroforum.com/viewtopic.p ... wheel+pins
i have no wish to pull motor out or take of gearbox..., there must be some other way how to get signal to ECU.. :twisted:
would it work if i put sensor and pins in/on front of crank ?? :-D
