fahrwerk
benquattro
fahrwerk
Beitrag von benquattro »
Hi, I'm new here. I have a 200 20v TQ.
I want to lower it, but the KW kit is very expensive.
Does a kit for the V8 also fit?
or one of these?
http://www.preisroboter.de/search.php?s ... &min=&max=
Greetings from Zolder
anstellwinkel
Beitrag von anstellwinkel »
Hi, if you only want to lower your car i would suggest only a lower spring kit. It is also the cheapest option. Basically, the suspension of 220V qt is the same as the V8. But the front spring rate of the V8 is usually a little bit higher than the 220V qt.
You are from Zolder? There`s a nice and famous racetrack. I´m driven already several times there.
Regards
benquattro
thanks for the response :)
I wil look for springs. The zolder circuit is 2km from my home, it's nice, but small :)
I want to ride on nordsleife :D
anstellwinkel
Yes, nordschleife is great. I drove this year in may with my Audi there and it is every time amazing.
Regards
