The electric diagram for my type 44 avant 1991
looks wrong. Is the Bentley manual only for American Cars ?
Or are the colour codes the same ??
(maybe i just need to take a closer look..?)
On the drivers side i found out, that a DEFA engine heater has been added, it looks like it is mixed up with the original wiring.
Maybe this is the reason for some of the weird electrics.
Is it possible to remove this ?
I think it will be difficult to find out what goes where...
This is the electric box in the engine compartment, connects to a heater in the engine.
Status:
I think i have to take the KI out first, and solder it:
Some lights doesent work, speedo is not working proberly
and Auto check makes a single sound when i turn ignition on, but without
"blink-code".
My fresh air fan only works if i hit it ! (contact ok, voltage reaching fan)
Could it be the carbon- brushes,
and can i change them ?
Okay, a lot of questions, hope you can help me.
cheers Birke
