instrument
urCquattro
instrument
Beitrag von urCquattro »
Hello Audi friends !
I hope it is ok that i write in english :-)
I was wondering , my tacho has white "double line" on center needle
but i would like to have red in/under center needle
what model had the red ? does it fit in my car , it looks some different
maybe it is possible topull of the needles and switch with mine ?
and when i am at it..:-)
does anybody know where to get white tacho table and chromringen ??
many thanks ,
Have a nice day
Regards
Martin
SWEDEN
urCquattro
Re: instrument
if you against all odds missed what type of Audi i have :-)
100 turbo quattro -87
Beitrag von André »
As I know, the instruments with the red needle are used with the Audi 200.
After the facelift (in 1988) the instruments are nearly the same between 100 and 200, but before facelift, they are not similar and not replaceable each other.
One point is the speedometer shaft/cable. The 100 has a mechanical one, but the 200 is electrical.
It could work, if you also replace the speed sensor at the gearbox.
But I think, the other electrical connectors must be custom fitted.
urCquattro
André hat geschrieben:As I know, the instruments with the red needle are used with the Audi 200.
Danke Andre.
Ok maybe try to change just the needle , but it is not easy to find , from a 200 .
GT5E
Beitrag von GT5E »
Hi Martin!
You can find some of these old Audi 200 Tachos in the german ebay.
Just type "Audi 200 Tacho*" and you'll get some offers.
You'll also find white tables (type "Tachoscheiben") and "Chromringe" / "Tachoringe".
Most of the sellers offer shipping to european countries but check this out first!
I don't know whether the red needles fit on the old instruments, and maybe you'll get wrong values on your speedo / rev counter, because of different needle weight.
Beside getting a Audi 200 Tacho with red needles, I would try to get another Audi 100 Tacho with white needles so that you can test the red needles on it without destroying your original Tacho. If your creation doesn't work you can re-replace it through the original Tacho.
Having destroyed the original and not having replacement would be bad I guess :wink: .
Greetings from Germany,
Markus
