Buergi chip for MC2
Verfasst: 29.08.2021, 01:29
von SamFM
Dear C3 friends!
Recently I've tested the KL-Racing chip with 1Bar wastegate spring, and I've noticed that new chip, compared to stock one,
doesn't use lambda and N7 (flow divider frequency) valve at all. So, I made a conclusion that KL chip just can't alter my fueling.
It can influence only on the ignition curves and removal of fuel cut-off.
Car become powerless below 3000 and it goes great afterwards, yes. But I think that there's something wrong.
Guys, do you know where I can buy a Buergi chip for my MC2 ?
Re: Buergi chip for MC2
Verfasst: 01.09.2021, 09:34
von timundstruppi
I offered you one at the end of 2020
Verfasst: 01.09.2021, 13:12
von SamFM
timundstruppi hat geschrieben: ↑01.09.2021, 09:34 I offered you one at the end of 2020
Yes, I am considering to take the offer. =)
Need a decent chip that uses lambda, fuel and ignition mapping.
By the way, will it be Ok if I use my wastegate spring rated for 1.0 Bar (not 0,9) ?
Verfasst: 02.01.2022, 10:16
von SamFM
Guys, sorry but I found a problem with ECU of my MC2. Seems like there are almost no decent auto-electricians in my city.
So I have decided not to go with Buergi chip before I will restore normal work for my ECU.
