MC2 Turbo questions
SamFM
Fuhrpark: Audi 100 Avant (MC2)
Mercedes W201 (M102)
Porsche 944 - Sold
MC2 Turbo questions
Beitrag von SamFM »
Hi guys!
I've recently sold A6 C6 and bought Audi 100 C3 Facelift instead.
It has front wheel drive, turbo MC2 engine and Avant body.
I've tried to get as much info as I can, but no one seems to know. So, I need your advice:
- Should the aftercooling pump turn on together with injector cooling fan or they act separate?
- Where can you get new resistor plate that mounts on the left side of the engine bay or can it be rapaired somehow?
- After I purschased my car, I had a wonderful acceleration and 1,4 bar boost shown on the instrument cluster, but about 200 km later, my boost dropped to 1.1 and car acceleration worsened a lot. I've checked car with VAG-COM, replaced every sensor that got faults, replaced main intercooler hose, replaced detonation and temperature sensors. But still same problem.
Could it be due to throttle position switch or intake temperature sensor (the one that is inside the intercooler)?
And does intercooler temperature sensor really affects something?
"You can't treat a car like a human being - a car needs love" W. Rohrl
sigare
Re: MC2 Turbo questions
Beitrag von sigare »
SamFM hat geschrieben: 07.10.2020, 16:48 - Should the aftercooling pump turn on together with injector cooling fan or they act separate?
no the aftercooling preserves the running of the fans and the coolandflow After engine shutoff to a certan temp them it stops (to high like afire is aswell protected) the relay is inside your footwel lefthandside next to the door
SamFM hat geschrieben: 07.10.2020, 16:48- Where can you get new resistor plate that mounts on the left side of the engine bay or can it be rapaired somehow?
TRS shop https://shops.audi.com/en_GB/web/tradition you can often find new oldstock parts.
SamFM hat geschrieben: 07.10.2020, 16:48- After I purschased my car, I had a wonderful acceleration and 1,4 bar boost shown on the instrument cluster, but about 200 km later, my boost dropped to 1.1 and car acceleration worsened a lot. I've checked car with VAG-COM, replaced every sensor that got faults, replaced main intercooler hose, replaced detonation and temperature sensors. But still same problem.
lack op boost can be
vacuumlines
sensors ed
but often the inlet temp sensor on the side oft the IC (next to the richt headlicht) can be faulty. two wires often break (wil not matter witch way te place them back)
fore more tips:
http://www.sjmautotechnik.com/trouble_s ... boost.html
SamFM hat geschrieben: 07.10.2020, 16:48Could it be due to throttle position switch or intake temperature sensor (the one that is inside the intercooler)?
[/quote]
wel look at he url :wink: http://www.sjmautotechnik.com/trouble_s ... boost.html
and mutch more http://www.sjmautotechnik.com/trouble_s ... ouble.html
SamFM
Porsche 944 - Sold
Beitrag von SamFM »
Hi sigare!
Thank you for the reply!
Now I understand much more.
Haven't thought that IC sensor is so important. Maybe thats why I lack boost.
I have a new problem now: car won't start, no spark. I checked G28 and G4 sensors - they are good.
Will try checking ignition coil driver and ECU.
sigare
do you have a alarm system?
on my car the alarm made the ecu not reciving anny 12v to start up
fought at first it was the hall sensor, thats as wel a culprit to no start
http://www.sjmautotechnik.com/trouble_s ... start.html
SamFM
Porsche 944 - Sold
Beitrag von SamFM »
Thanks for trying to help!
I don't have alarm on my car.
And I've found a problem of no-start:
Weirdly, it linked to the steering damper (https://www.drive2.ru/l/479725170609619339/ ) I have installed additionally. It mounts between the steering rack and the firewall.
So, after installation the motor wiring loom has been torn apart by steering link. So, after the wiring was fixed, the car started no problem.
Now, I'm trying to make my N75 valve work when I accelerate. Currently, seems like the ECU just doesn't send the - signal to N75.
I've checked the intercooler temperature sensor - it's OK and showd 505 Ohm when cold.
Next step - test my throttle position sensor, I guess.
SamFM
Porsche 944 - Sold
Beitrag von SamFM »
A little update,
I've changed the intake boot (found good used one) and repaired the old electrical connections on the throttle switch.
Finally, N75 didn't work because there was no signal from the full throttle switch.
The turbo pressure become 1.3 above 4000 rpm, instead of 1.1-1.2
But still, I feel that N75 is being "lazy".
Recently I've found out that the vacuum hose that goes to the "elbow" near turbo intake, was pulled out.
I put it back but it didn't help. Will continue to look further. =)
sigare
low boost, normaly the boost will be 1.4
thats reading material in the section from SJM.
all sensors all conectors and all the hose need to be 100%
blowby the mainfold wil not help as wel as a leaking turbo ere exhouset
