Noch was und sogar noch billiger.
Odometer Gears
Odometer Gears
HOME |
AUDI | BENTLEY | BMW | CHRYSLER/DODGE | FORD | GMC/CHEVY | INFINITI | JOHN DEERE | LA FORZA | MERCEDES |
| NISSAN |PORSCHE | ROLLS | SAAB | SATURN | VIXEN | VOLVO | VW | FAQ | MECHANICAL/LEAD GEARS | LINKS
Odometer Gears
AUDI - $25 EACH plus $4 Priority Mail anywhere in the world (unless otherwise noted)
Electronic Units - Odometer Gears
LIFETIME WARRANTY ON OUR PRODUCTS
MECHANICAL (CABLE DRIVEN) GEARS CLICK HERE
Product List
Odometer Gears
1986-1992 80 series (B3-B4), 1988-1995 90 series (B3-B4)
It is always best to count the teeth on the old gear before ordering.
15 tooth gear
$25/each
Odometer Gears
1982-1991 5000 (C3)
26 tooth gear
$25/each
Odometer Gears
12 and 16 tooth base pod
$25/each
Please pick your tooth count
Odometer Gears
1982-1991 5000 (C3)
15 tooth large base pod
$25/each
Odometer Gears
Odometer Gears
Late Model
Audi
When you first turn the ignition switch to the run position, all of the gauges move to the furthest mark of the gauge and then resets to the lowest (sweeps low to high). There is one gear per gauge: speedometer, tachometer, temperature and fuel. These gears are located inside of the stepper motor that attaches to each needle. These gears are mainly for repair facilities as you must use a VAG-COM to initialize and synchronize the motors after repair. The pictures to the left have a pencil eraser in the middle for size comparison as these gears are very tiny.
E7 gear
$18/each
If you have questions, please email or call anytime. Weekends and evenings are ok.
sales@odometergears.com
757-593-3478 (Jeff)
757-771-6694 (Darren)
You can also text message to the above numbers
Odometer Gears
Copyright © 2010 GoGo Advertising, LLC. All Rights Reserved.
Oskar
